I am trying to solve a problem on using an FET transistor as an amplifier with the common source configuration. The model should be appropriate for high frequencies.
The problem gives the equivalent circuit for the AC analysis like below where gm is 4 mA/V:
To model the circuit I used the DC circuit of the amplifier with common source and ended up with this:
I found that Rg = Ri and Rs is given. But I am having difficulty in finding Rd and proper Vcc and Vss sources to make it work. Any advice on how to approach this problem would be appreciated.
