Firstly, I want to make a BLDC motor WITH hall effect sensors to maximize the torque. I have a heavy mountain bike and I love to make long trips with it. But in my city, there are REALLY steep mountains which can be challenging with extra luggage. I want to make a compact BLDC motor in the rear or front hub which can make a little boost on the hills. I need torque, not speed. I'll use it just for boost, I won't convert my bike into a motorcycle.
So, I designed a BLDC motor that isn't so accurate for maximum torque but gives an idea for the design. I will start from inside to outside. First, we have a shaft in the center which is linked with 8 neodymium magnets around it. Then, we have the case which has the 3 phase coils and hall effect sensors in it (probably I will use 3 hall effect sensors). Then, we have the electronics which are linked with coils. And last, we have the lithium-ion batteries linked around the case. I'll add one of the lithium-ion batteries for better understanding. The volt and amp can be changed; it is for better understanding.
The magnets are not moving; coils, electronics, and batteries are spinning with the wheel.
I hope the photos will be helpful. I will also make it waterproof and dustproof so it can't have the cold wind in it. So I taught that I can fill it with engine oil. The outside will be aluminum so it will be cold I think.
Now, let's come to my questions. As I said, I'm 10th grade and don't know so much about electrical engineering.
My first question is: When BLDC motors off, do they affect my normal riding, like convert my power into electric or just make so much friction because this is a motor? I mean, when I don't pedal, does bicycle stops faster than before?
Second question: I don't know so much about how to install hall effect sensors. I googled it and find some info. But if you can tell a little bit again, it will help so much. And I know I should use ESC but I don't know how to install it, like which cables in my motor will go where?
Third question: What upgrades can I make for high torque, low speed?
Fourth question: How thick wires should I use like 250watt motor and how to wind them?
Very thanks for reading this and I hope you understand what I meant and you can answer my questions. Sorry for my bad English.
