I was reviewing block diagrams on this tutorialspoint page and it showed how an RLC circuit is written with a feedback loop. It occurred to me that any time a block diagram of a circuit is created, there has to be a summing joint, hence there will be feedback On the one hand, this seems natural because for a circuit to function, it has to have a path for current to flow and so there is a type of loop created. On the other hand, I have never heard it mentioned that the block diagram of every circuit must have a feedback loop. It also seems different from my intuitive concepts of feedback though I admit my intuitive concepts are wrong a lot.
Is it true that the block diagram of any electrical circuit has a feedback loop?enter image description hereenter image description here
    \$\begingroup\$ Does a lightbulb with an on/off switch and a supply need a feedback loop? \$\endgroup\$
    – Solar Mike
    Commented Apr 3, 2020 at 6:42
  • \$\begingroup\$ The diagram, considering only the components you show, is very incorrect. \$\endgroup\$
    – tuskiomi
    Commented Apr 3, 2020 at 7:25
  • \$\begingroup\$ @SolarMike we can have a feedback by putting wire resistance: \$i = \frac{1}{R}(V_{i} - V_{o})\$. Basically a voltage divider is a feedback loop. \$\endgroup\$
    – across
    Commented Apr 3, 2020 at 7:35
  • \$\begingroup\$ I believe your question to be true. Whether it's useful in all cases to convert a simple circuit to a more complex one with a feedback loop(s) is another matter. Some (a few) circuits are very useful to analyse when converted to have a feedback loop. \$\endgroup\$
    Commented Apr 3, 2020 at 8:21
  • \$\begingroup\$ The 'summing joint' is only a possible implementation (according to KCL) of the summing device (the circle in the block diagram above) that can be named 'parallel voltage summer'. Inverting circuits with negative feedback are based on this device. Another possible implementation is the 'summing loop' (according to KVL). Noninverting circuits with negative feedback are based on this 'device'. However, the simplest negative feedback circuit (without input) does not need such a device. It consists only of an inverting amplifier which output is connected to its input. It keeps zero output voltage. \$\endgroup\$ Commented Apr 3, 2020 at 12:41
4 Answers 4
Keika, the answer to the question in your headline is "NO".
I think, it is not correct to say that the RLC circuit is "written with a feedback loop" or that "every circuit must have a feedback loop".
What you have done is the following: You have created ANOTHER fictitious system (with feedback) that has the same output-to-input ratio as your passive RLC circuit. That`s all. However, it has another input impedance and another output impedance. Hence, both are not identical - both have only the same ratio Vout/Vin.
More than that, if you define the output voltage across the inductor or across the resistor, these voltages are NOT available in the second system (with feedback). This is another indication that both are not identical.
There are many other circuit alternatives (second-order lowpass with unity gain) having the same output-to-input ratio but with different input- and output impedances.
EDIT 1: It is really interesting - when you multiply the first Block with "R" and - at the same time - divde the 2nd block by "R", you get two new blocks. This is allowed because the series connection of both transfer functions does not change.
The first one is a damped integrator (lowpass) and the 2nd one is an IDEAL integrator. This gives the classical active "state variable" structure which is nothing else than one alternative for an active realization of the passive reference structure.
EDIT 2: If we describe the voltage-current properties of the passive RLC circuit in the time domain we arrive at a differential equation which can be transferred into an integrating equation. A blockwise realization of this relationship leads to the well-known state variable filter realization as mentioned under EDIT 1. Hence, this system with two integrating blocks and a feedback loop is an active realization of the passive RLC reference circuit. As a result, we have two different circuits (passive, active) having the same transfer function. The feedback circuit as shown in the task desription is a slight modification of this arrangement (as explained under EDIT 1).
It doesn't need to have a feedback loop, you could rearrange it in many different ways. However, writing it so it has a feedback loop allows you to apply all the knowledge you already have from control engineering since the shape/structure is there same.
It does not need it, but it can be helpful to represent it in that way in some applications. Remember that the blocks after the summing joint represent the "model" of the object itself, be it a circuit, or some other system.
edit: You could add compensation after the "model" blocks, so I will warn you about that.
  • \$\begingroup\$ Thanks for the reply. Can you give an example of how a circuit can be written without a feedback loop? The block diagram of every circuit I draw, no matter how simple, ends up with a feed back loop. \$\endgroup\$
    – keika
    Commented Apr 3, 2020 at 7:01
  • \$\begingroup\$ @keika you definitely did not have to write that circuit as a closed loop, not even sure why someone would do that. As the "feedback loop" is just physics laws and not really some type of control system. \$\endgroup\$
    – jDAQ
    Commented Apr 3, 2020 at 7:10
  • \$\begingroup\$ Also, you could just write that, if you so keenly intend to, as a single block and have an "open loop" system with input \$V_i\$ and output \$V_o\$, the transfer function would be just: $$G(s) = \frac{1/sC}{ R+sL+1/sC}$$ \$\endgroup\$
    – jDAQ
    Commented Apr 3, 2020 at 7:14
  • \$\begingroup\$ I understand it is just physics and not some type of control system. I also realize we can convert the closed loop to open loop afterwards. Can you show me how to write the block diagram of a circuit without using a closed loop to start with? \$\endgroup\$
    – keika
    Commented Apr 3, 2020 at 7:16
  • \$\begingroup\$ @jDAQ Our replies crossed but I will let me question stand since I cannot derive your equation from the circuit by inspection. I have to write out the closed loop equations and then convert it to open loop. So it still seems like, at the least, every circuit can be written as having a feedback loop. \$\endgroup\$
    – keika
    Commented Apr 3, 2020 at 7:20
In the block diagram representation, you replace each circuit block with its gain. Although you have \$\frac{1}{R+sL}\$ and \$\frac{1}{sC}\$ blocks in your original circuit. You don't have any circuit block which performs the difference operation. Thus, the block diagram you specify for the RLC circuit is incorrect.
Note, that in a real feedback circuit, for example a unity gain buffer as shown below. There is an actual circuit performing the difference operation, the differential amplifier (OA). And since the differential amplifier is amplifying the difference between the input and output voltages, you can include the "difference operation" in the block diagram as well. Each element in the block diagram has to correspond to a sub-circuit in your design.
    \$\begingroup\$ Sarthak- if you read my detailed answer (EDIT) you will see that it can prooved that the shown feedback arrangement is correct. Did you not realize that the input summing junction performs a difference operation? \$\endgroup\$
    – LvW
    Commented Apr 3, 2020 at 11:27
  • \$\begingroup\$ Where is the input summing junction in the original circuit? Are you saying that the given circuit has feedback? \$\endgroup\$
    – sarthak
    Commented Apr 3, 2020 at 11:53
  • \$\begingroup\$ A circuit with negative feedback does not obligatory need a summing or subtracring device (the circle in the block diagram). It can be implemented simply by connecting the output of an inverting amplifier to its input. The role of the "circle" is to introduce another (input) voltage acting as an additive disturbance. The amplifier reacts to it by producing output voltage that is equal to the "disturbing" input voltage. So, the whole circuit (an amplifier and a summer/subtractor) acts as a voltage follower. If we insert a multiplicative disturbance (attenuation) in the NFB, it will amplify... \$\endgroup\$ Commented Apr 3, 2020 at 12:16
  • \$\begingroup\$ @Circuitfantasist As I explained in the answer if you feed back the output of the follower to the input the amplifier is the one doing the subtract operation. In any case, a feedback circuit needs to compare its output to the input to ensure that the error is small. To check the error, the computation of the difference is a must. \$\endgroup\$
    – sarthak
    Commented Apr 3, 2020 at 12:22
  • \$\begingroup\$ Sarthak...it was a misunderstanding...I was of the opinion, you were referring to the second circuit. Nevertheless, you are not right. A passive RLC circuit can produce a transfer funktion with complex poles (as you certainly know). On the other hand, wenn a circuit (or a series of two blocks, as in our case) produces REAL poles only, a feedback loop is able to shift the poles in the complex plane...and that is the case here !! \$\endgroup\$
    – LvW
    Commented Apr 3, 2020 at 12:42
Great question. You are asking essentially 'what is feedback?'. Suppose you had a transmission line driven by an un-matched source and terminated with an un-matched impedance so that you get a reflections. Here we would say that there is feedback as we see a time delay, reflection/propagation, and combination at the terminals. The signal transient shows a damped ringing response modeled as a feedback loop (s-parameters). Now consider a resistor divider vs-r1-r2-gnd driven by a step source vs at r1. How does the circuit 'know' what value of current and what voltage across each resistor is required? If we imagine a propagation delay we 'see' a current transitioning from the source through r1 to r2, a buildup of potential at r2 which modifies the current into r2 with 'feedsback' information to limit the current to (vs-v2)/r1 as v2 builds up to its final 'steady state' value of the divider output. The delays involved here are super small so we assume them to be instantaneous as opposed to the delay line we started with. Adding a capacitor at r2 enhances this transient feedback effect (adding delay) but we analyse this in closed form as ~exp(-t/tau) rather than a feedback summation of delayed (transmission line) wavelets, a feedback loop as you point out in your example. Feedback is physical and it is modelled. The model may hide the feedback or it may focus on it. This differentiation between physics and math has been one of the main difficulties in understanding feedback system behaviour. So again, great question!
  • \$\begingroup\$ Agustin O....There are some points I cannot follow: (1) "How does....are required". What do you mean with "required"? The voltages (better: the E-fields within each resistor) depend on the resistors conductivity only. Thats all!. (2) "...build up of potential ar R2 which modifies the current...to limit the current...as V2 builds up to is final value...". This sounds to me as if you think that the current through R2 would PRODUCE the voltage across R2. But this is, of course, not the case. In contrary , it is the voltage across (the E-field within) R2 which enables the current through R2. \$\endgroup\$
    – LvW
    Commented May 15, 2020 at 16:53
  • \$\begingroup\$ Again physics vs model. We get the final value of current in a resistor divider stabilized at the required nodal voltages. V2=Vs/(R1+R2) * R2 but how does the circuit get to these results? The voltage at V2 builds up (very quickly) and feedsback information such that this is achieved in the physics. The math model jumps to the final 'required' result... As for current vs E field, isn't this perspective? If I inject a current into R2 does not this 'cause' the voltage/Efield response? If I apply a voltage/E-field then the response is current. \$\endgroup\$ Commented May 15, 2020 at 17:54
  • \$\begingroup\$ No - the last part of you answer is not correct. To "inject" a current into a resistor is a kind of labor jargon - but physically not correct. We cannot "inject" a current - we only can connect a resistor R2 to a voltage source with a very large source resistance Rs. That means: We still have a voltage division between a very large Rs and a comparale small resistor R2. There is no "feedback information" within such a two-resistor chain. \$\endgroup\$
    – LvW
    Commented May 15, 2020 at 18:53
