We all know that an electric motor can be reversed to generate electricity. My question is, will it work the same way if I were to do this in an EDF?
The EDF that I’ve been watching, is producing 35 kW at around 18k RPM, that’s all I care about. Now, let’s say this EDF is driven by an engine, will it still produce approx. 35kW at around 18k RPM?
Second question, if an electric motor is rated at 15kW, 8,000 RPM. What if this motor is driven by an engine at 12,000 RPM. Will I be able to produce more than 15kW? Assuming, we have a proper cooling system.
