I have started to research about electrical motors and batteries.
I have learned physics in high school and I understand electricity. My question is whether an engine's power depends on its RPM or not. Let's say the specification says its 1V at 1 Amp, does it give me 1 watt at any operating RPM or a constant force, which gives 1 watt at maximal RPM? Maybe the resistance depends on RPM?
Because if it gives a constant force, the power is P=VF and I need gears if I want dynamic acceleration (like in cars, the acceleration starts high and is reduced with speed), and if the power is constant then the force starts high and is reduced, giving me optimal acceleration and force at any time. I think that its constant power, because electrical cars are single-speed (only one gear ratio). (contrary to internal combustion engines which its power varies by the RPM).
