For a 100 meters RG58 coaxial cable, according to the datasheet, the capacitance of the cable is 10 nF and the inductance is of 25 µH approximately. A sinusoidal voltage is applied at the input of the line with a 50 Ohm source, and the end of the line is connected to an oscilloscope, HZ mode (1 MOhm//10 pF), AC coupling. This give, according to me, the following schematic:
The RG58 coaxial cable is replaced by the lumped element R,L,G,C, G is neglected.
The simulation of this circuit with LTSpice, and theoretical calculation give an upper cutoff frequency of 300 kHz approximately. However, I personally made the measurement with a 100 meters RG58 coaxial cable and the measured -3 dB bandwidth is of 5 MHz approximately. (I don't recall the exact measurement value, sorry)
The coax cable model(picture below) gives a value in perfect agreement with measurement
Once again, I don't have a screenshot of the simulation result, sorry.
I do not understand why the measurement and the simulation of the coaxial cable give a cutoff frequency greater than the one given by taking into account only theoretical effect of the parasitic capacitance. Every physical phenomenon I neglected such as skin effect, or conductance of the dielectric should lower the upper cutoff frequency.
