I have an application that requires optical transmission of 4x16 Gbps SERDES lanes over fiber. A QSFP28 module for 100G ethernet seems like a great commercial solution--it can take the four lanes and combine them over a single fiber channel. The only hitch is that all of the QSFP28 modules I can find are only characterized over a narrow electrical lane rate, about 25-27 Gbps.
Here's an example from FS, but it's a similar story for all vendors I've checked: https://www.fs.com/products/75309.html
I understand why the datasheet recommended range is so limited, since they are designed for a singular networking application. However, my gut also says that a lower but not-too-low lane rate like 16 Gbps would be okay for the internal SERDES transceivers. It would also enable the modules to be used in 40G/4x10G applications, so I'm wondering if there are any resources that would serve as evidence to this point.
Additional Research
I accepted Joren's answer since it showed quite clearly that the limitations of the CDR/retiming functionality of QSFP28 modules would be the foremost barrier. I also did a little research that I want to share here. There is a workaround provided in the QSFP28 memory map. See the snippet below from SFF-8636: Management Interface for 4-lane Modules and Cables, which shows that it is possible to disable retiming functionality. This presumably comes at the expense of signal integrity at the receiving end and consequent maximum link length.
I'll probably run some tests, and also take advice to look at alternate fiber specifications.
