Usually, in most cell designs, the concept of two-electrode design is the baseline. The two electrodes are anode and cathode where the electron transfer happens between them. However, I have been reading about 3 electrodes and 4 electrodes designs where the new electrodes are used to control the potential while allowing the working electrodes to deal with the current transfer. However, I wanted to know how to control the potential of my cell and what is the equations for that if I want to build my own multi-electrode cell.
Thank you
  • \$\begingroup\$ First, what is the cell doing? Electrolysis, plating, hydrogen generation, measurement of chemical reactions, or is it a battery? \$\endgroup\$
    – user16324
    Commented Aug 26, 2020 at 18:36
  • \$\begingroup\$ it is a battery \$\endgroup\$ Commented Aug 26, 2020 at 18:40
  • \$\begingroup\$ You measure the Impedance mismatch and voltage mismatch and then balance the differences to <<1% amd stay well within the chemistry voltage operating range. \$\endgroup\$
    – D.A.S.
    Commented Aug 26, 2020 at 19:12
