Say we have this circuit. Then we were asked to find Vo using iterative analysis. We were told to stop when the estimate is accurate to within 15mV. I just want to confirm my understanding of the question.
- Is the 15mV the Vo that we should be aiming to get?
- And so, if it is, we should be looking for the values of Id or Vd, right?
- What will be the right approach here? Could I first assume Vd to be 1/2Vout (Since I could find Id when I know Vd) and then just adjust it till I get to 15mV?
My KVL equation is: (Id is based from the exponential model of the diode) $$ Vout = V1 - iD(R1) - 2Vd $$
The following are given: Is (reverse sat. current) = 1fA Ideality factor = 1 Operating temp = 27 C
