I have some trouble with my LM2576-5.0WT. I have an input source of 12 V (8 A max), and I want to convert it to 5 V (3 A maximum.)
Hence I built my circuit as the one on the first page of this datasheet..
On my PCB (with other things) I have trouble with the 5 V. It changes with the load, and it's 10 V with no load (at the beginning I got 5 V, but not anymore).) My PCB is more complex but the schematics of that part is like this:
Hence, I made a simple circuit (same as in datasheet, so without the delay (Cd1 and Rd1)) with breadboard. I got 5 V without load. But when I put a motor as a load, to test it, the voltage decreased to 4.1 V. Why is the voltage not stable? How can I have always 5 V? I need to supply a RPi, so I need 5V - 3 A. You can find below my test circuit (same as in the datasheet).
NB: list of component (the codes are from RS, sorry I cannot put more than 8 links)
- LM2576-5.0WT: 9101966
- Cin 100 µF: 7111731
- D1 - 1N5822: 6870877
- L1 - 100 µH: 1048443
- Cout - 1000 µF: 7111312
