I have an Adafruit Feather ATMega 32u4. I want to put it into sleep mode and wake it up with pressing a switch as an external interrupt. This is what I tried so far and which worked:
- switching a LED on and off with the switch
- putting the Adafruit to sleep and let it wake up with a watchdog timer. I tried to combine the code examples that I found in the Internet to make the code fit my board. I manage to put it to sleep but then I have to reset it because the Interrupt doesn't work. I would be very happy for any help and please don't blame me, I am a complete beginner!
Here is my code:
#include <avr/sleep.h>
#include <avr/power.h>
#include <avr/interrupt.h>
int pin2 = 2;
void pin2Interrupt(void) {
/* This will bring us back from sleep. */
detachInterrupt(digitalPinToInterrupt(2));
void enterSleep(void){
/* Setup pin2 as an interrupt and attach handler. */
delay(100);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
attachInterrupt(digitalPinToInterrupt(2), pin2Interrupt, RISING);
if (digitalRead(pin2)){
sleep_mode();}
/* The program will continue from here
First thing to do is disable sleep. */
sleep_disable();
void setup(){
Serial.begin(9600);
/* Setup the pin direction. */
pinMode(pin2, INPUT_PULLUP);
Serial.println("Initialisation complete.");
int seconds=0;
void loop(){
delay(1000);
seconds++;
Serial.print("Awake for ");
Serial.print(seconds, DEC);
Serial.println(" second");
if(seconds == 3){
Serial.println("Entering sleep");
delay(200);
seconds = 0;
enterSleep();
