PCB:
My name is Ertuğrul. I made a regulation board with an LM2678 but I have a problem: I provide 12V input but I can not get 5V output.
I only get 5V with the on/off pin enabled, but the datasheet says that I can get a 5V output with the on/off pin not active.
I have to give 1.4-6V to the on/off pin because otherwise it does not work.
I tried it on a breadboard but it did not change. I used Webench schematic design.
Do you know about LM2678? Can you help me ?
