6
In December 1947 Bardeen, Brattain and Shockey introduced a device which is considered to be the first transistor. This transistor was point-contact device. So, it used metal-semiconductor junctions. According to book History of semiconductor engineering by Bo Lojek (2010), a principle of such transistor has never been fully understood:
...but as matter of fact, a good solid physical theory of point-contact transistor does not exist and even today we do not know, for example, why point-contact transistors occasionally exhibit negative resistance behavior.
As to produce point-contact transistor (or diode) is rather art (because each piece of semiconductor can have different impurities, damaged crystal grid etc. and it also depends where a metal contact is made), it seems obvious that each transistor could show different behavior (mentioned negative resistance, unstable gain etc.). These were reasons why Shockley worked out theory of P-N junctions and based on it introduced junction transistor which behavior is predictable.
I understand that point-contact transistor is now very obsolete device, however, I wonder if there is (or was) any research trying to understand point-contact transistors functions. Any information, paper etc. will be highly appreciated.
Cross-posted on SE.Physics
    \$\begingroup\$ Negative resistance could be due to thermocouple effect on the interfaces coupled with transient temperature.. [?] \$\endgroup\$
    – Damien
    Jan 7, 2021 at 5:37
Disclaimer: I do not pretend this to by an answer. Rather, a bit elaborated comment.
As I read, what they were looking into was a way to circumvent surface-states characteristic detrimental effects due to energy-dependent charge storage close to the interface (aka near-interface traps, NIT). The presence of permitted states within the Germanium band gap was a clear obstacle (well, in those days it wasn't clear at all) to the Gate establishing overall FET operation. Therefore, the idea was to bypass the use of Gate and Oxide structure and rather directly inject metal probes to the Ge surface and see what happens: what they got was a crude bipolar-like device operation where these needle took the role of E-C contacts.
Source:
Shuji Hasegawa, François Grey, Electronic transport at semiconductor surfaces––from point-contact transistor to micro-four-point probes, Surface Science, Volume 500, Issues 1–3, 2002, Pages 84-104, ISSN 0039-6028, https://doi.org/10.1016/S0039-6028(01)01533-3
[...] it seems obvious that each transistor could show different behavior (mentioned negative resistance, unstable gain etc.)
Definitely so, as they were pioneers in that field. They couldn't get nowhere near what modern device processes are able to deliver: nowadays we know how quality oxide can be grown on top (e.g. SiO2) of Silicon, what crystallographic surfaces fit best such process, POA treatments and so on. Without that, a large defect density is definitely to be expected, leading to significant device variability -- however, I don't know about these "negative resistance" effects.
Not actually, as such idea is still used in some novel electron devices under research; the context though is completely different, of course.
