The question is as shown below: enter image description here
The answer from the book is as follows: enter image description here
However, below is my attempt, is my approach accurate?
    \$\begingroup\$ Thank you for posting the full question and your fully-documented attempt at an answer! That's a great example that everyone should follow when posting this type of question. But please do add the 'homework' tag to your question as well. \$\endgroup\$
    – Mr. Snrub
    Commented Jan 19, 2021 at 8:32
    \$\begingroup\$ You were sublime until the KVL equation. You messed the signs. Since you enter the resistor R2, it should be like: R2Id - 6 + Vgs = 0. The rest follows and if you correct that bit, all will be fine. \$\endgroup\$
    – a360pilot
    Commented Jan 19, 2021 at 8:33
1. Your calculation for R2 contains a sign error
Double-check your equation $$ -v_{gs} + i_dR_2 - 6 = 0 $$ There is a sign error in there. It looks like you're using KVL; double-check and be very detail-oriented in how you apply KVL. Correct the sign error and you will get the correct answer.
2. Your calculation for R1 is correct -- actually more correct than than the "solution"!
By your calculations you end up with a value of 4.8kΩ. In the answer key they just round this to 5kΩ: $$ R_1=\frac{6V-1.2V}{1mA}=4.8k\Omega \approx 5k\Omega $$
    \$\begingroup\$ You swapped the resistor tags. Replace R2 and R1, please. In the titles, I mean. \$\endgroup\$
    – a360pilot
    Commented Jan 19, 2021 at 8:42
  • \$\begingroup\$ @BenFM D'oh! Thanks. Fixed. \$\endgroup\$
    – Mr. Snrub
    Commented Jan 20, 2021 at 2:51
