This is my wiring here:
is connected to 3v3, -
to GND and OUT
to pin28.
I'm using this example found on raspberry-pico official examples.
#include <stdio.h>
#include <math.h>
#include "pico/stdlib.h"
#include "hardware/gpio.h"
#ifdef PICO_DEFAULT_LED_PIN
#define LED_PIN PICO_DEFAULT_LED_PIN
#endif
const uint DHT_PIN = 28;
const uint MAX_TIMINGS = 85;
typedef struct {
float humidity;
float temp_celsius;
} dht_reading;
void read_from_dht(dht_reading *result);
int main() {
stdio_init_all();
gpio_init(DHT_PIN);
#ifdef LED_PIN
gpio_init(LED_PIN);
gpio_set_dir(LED_PIN, GPIO_OUT);
#endif
while (1) {
dht_reading reading;
read_from_dht(&reading);
float fahrenheit = (reading.temp_celsius * 9 / 5) + 32;
printf("Humidity = %.1f%%, Temperature = %.1fC (%.1fF)\n",
reading.humidity, reading.temp_celsius, fahrenheit);
sleep_ms(2000);
void read_from_dht(dht_reading *result) {
int data[5] = {0, 0, 0, 0, 0};
uint last = 1;
uint j = 0;
gpio_set_dir(DHT_PIN, GPIO_OUT);
gpio_put(DHT_PIN, 0);
sleep_ms(20);
gpio_set_dir(DHT_PIN, GPIO_IN);
#ifdef LED_PIN
gpio_put(LED_PIN, 1);
#endif
for (uint i = 0; i < MAX_TIMINGS; i++) {
uint count = 0;
while (gpio_get(DHT_PIN) == last) {
count++;
sleep_us(1);
if (count == 255) break;
last = gpio_get(DHT_PIN);
if ((i >= 4) && (i % 2 == 0)) {
data[j / 8] <<= 1;
if (count > 16) data[j / 8] |= 1;
j++;
#ifdef LED_PIN
gpio_put(LED_PIN, 0);
#endif
if ((j >= 40) && (data[4] == ((data[0] + data[1] + data[2] + data[3]) & 0xFF))) {
result->humidity = (float) ((data[0] << 8) + data[1]) / 10;
if (result->humidity > 100) {
result->humidity = data[0];
result->temp_celsius = (float) (((data[2] & 0x7F) << 8) + data[3]) / 10;
if (result->temp_celsius > 125) {
result->temp_celsius = data[2];
if (data[2] & 0x80) {
result->temp_celsius = -result->temp_celsius;
} else {
printf("Bad data\n");
When I use serial debug I should get something like Humidity = 50%, Temperature = 10C
but the only thing I'm getting is Bad data
and Humidity = 0%, Temperature = 0C
What am I doing wrong here?
EDIT
The sensor is working on my Arduino UNO.
I've now tried UART connection since someone told me that the USB Serial could be interrupting.
This is my wiring: 1, 2, 3
I've activated Serial Port and Serial Console on my Raspberry Pi Pico and did minicom -b 115200 -o -D /dev/ttyS0
but no output is set.
Bad Data
String \$\endgroup\$if()
statement that leads to the "Bad data" message). Where do you want the question to "live" - here (if you have an oscilloscope or logic analyser)? Or on Stack Overflow for s/w (if you don't)? \$\endgroup\$
