I need 24VAC 300ma for a solenoid and have these old transformer power packs with outputs of: 9vdc, 12vdc, 15vdc, 32vdc. I'm willing to crack open one and use the transformer but I only want to open the one that would have or be close to having the 24VAC secondary.
Which one's the lucky one.
The solenoid specs: 24Vac 50Hz 8VA > 8VA / 24 = 333ma should work fine?
Unfortunately it was a successful failure. I got the 24VAC from the Power pack but on connecting a distinct unhealthy hum was present from the solenoid with 24VAC at 370ma. It did not sound right.
I then tried DC power packs I have and all quiet, no humming just V/V opening and closing sound:
12VDC at 250ma
18VDC at 490ma
24VDC at 570ma
30VDC at 770ma
Solenoid says 'ac' but works better with DC, I have absolutely no idea!
