I have a 12V "non-spillable sealed lead acid battery" (the UPS type) that is labeled to be 9Ah (it is almost new). When I fully charge it and then discharge using a discharger that counts ampere-hours (at 0.5A), it measures only about 6Ah. Is this expected behavior, or should it be closer to the rated capacity for a properly functioning battery?
Also, how much does the discharge energy depend on the current at which it is being discharged? Label says "9Ah/20HR", does this mean that optimal capacity can be reached when discharging for 20 hours (which would be 0.45 A)?
