I have an old headlamp that I've been trying to fix - it takes 2 AAA batteries and doesn't work even with new batteries. I opened the headlamp up to see if I could figure out what was wrong. When I connect positive and ground to the soldered pins of each LED individually, they all light up. I can't seem to figure out how to get all of them to light up at the same time. In other words, I can't figure out how this circuit is wired.
In one of the pictures, I show I a close-up of the button. It is a rubber button that simply taps on one side of the circuit (I assume it is coated in something conductive.) I'm relatively inexperienced with electronics and I would appreciate it if someone could help me understand this board. I suspect the corroded metal has caused problems, but I'd still like to see how it works.
Also, I'm not sure what the chip-on board-does.
