I've a Bluetooth + Aux speaker which needs to be turned On manually after giving power. I wanted it to start functioning as soon as I switch the power On.
I opened it, there was a tactile push button which needed to be pressed for around 1.5 seconds to turn the speakers On. I solded both wires (on one side) of push button with each other. It worked and speakers start working after giving power.
Now the problem is; since the switch is treated as constantly pressed, inputs of other switches (volume, mode, lights) are ignored by the controller.
I'm not a professional, just an amateur hobbyist. How it will be possible to pass current between two pins of push button for only a few seconds when power is switched On?
