I have a lists of current and voltage of one device and I would like to calculate the resistance. There are some errors with the coordinate, so I have made a script where I calculate the line by linear regression.
from scipy.stats import linregress
import matplotlib.pyplot as plt
import numpy as np
import pandas as pd
voltage = np.array([1, 2, 3, 4, 5, 6, 7, 8, 9, 10])
current = np.array([3, 6, 6, 10, 9, 15, 14, 16, 20, 25])
slope, intercept, r_value, p_value, std_err = linregress(voltage, current)
print(linregress(voltage, current))
plt.plot(voltage, current, 'o', label='original data')
plt.plot(voltage, intercept + slope * voltage, 'r', label='fitted line')
plt.xlabel('Voltage')
plt.ylabel('Current')
plt.show()
Which plots me: enter image description here
and prints:
LinregressResult(slope=2.206060606060606, intercept=0.2666666666666675, rvalue=0.9703665463597563, pvalue=3.2552108142876276e-06, stderr=0.1942232770783282, intercept_stderr=1.2051237414984548)
What is the value of the resistance for this device, how to calculate it from line?
    \$\begingroup\$ If your "device" is not an ideal resistor then the notion of calculating its resistance is not valid. \$\endgroup\$ Commented Nov 3, 2021 at 19:11
4 Answers 4
Look at Ohm's law for resistors:
V = I x R
Then solve it for R:
R = V/I
Looking at your graph, the slope of the line is I/V, which is the reciprocal of R.
So R = 1/m
Where m is the slope of your graph.
Ohms law tells us \$V=IR\$, so \$R=\frac{V}{I}\$, so \$\frac{1}{\text{slope}}\$ is your resistance.
I suspect your current number are actually milliamps and not amps, so you need to correct for that.
A more meaningful way to do this is to force your line fit to have a zero intercept.
  • \$\begingroup\$ Thank You for helpful answer! It is on point, however mkeith was slightly faster so I decided to accept his answer. \$\endgroup\$
    – Jerzy
    Commented Nov 4, 2021 at 10:25
First make sure both units have the same magnitude (V and A, mV and mA etc).
Second, if you force the intercept to zero and switch V with A, so the slope is directly the resistance, the code becomes simply:
import numpy as np
resistance = np.sum(voltage*current)/np.sum(current**2)
print(resistance)
Using Mathematica I make the following picture:
The equation of the line of found using the least square method and is given by:
$$\text{Current}\left(\text{Voltage}\right)=\frac{364}{165}\cdot\text{Voltage}+\frac{4}{15}\tag1$$
We know Ohm's law:
$$\text{R}\space\left[\Omega\right]=\frac{\text{V}\space\left[\text{Volt}\right]}{\text{I}\space\left[\text{Ampere}\right]}\tag2$$
So, we can write:
$$\text{R}=\frac{1}{\text{Current}'\left(\text{Voltage}\right)}=\left(\frac{\text{d}\text{Current}\left(\text{Voltage}\right)}{\text{dVoltage}}\right)^{-1}=\frac{165}{364}\approx0.453297\space\Omega\tag3$$
The Mathematica-code I just is:
y = Fit[{{1, 3}, {2, 6}, {3, 6}, {4, 10}, {5, 9}, {6, 15}, {7,
     14}, {8, 16}, {9, 20}, {10, 25}}, {1, x}, x];
Show[ListPlot[{{1, 3}, {2, 6}, {3, 6}, {4, 10}, {5, 9}, {6, 15}, {7,
    14}, {8, 16}, {9, 20}, {10, 25}}],
 Plot[y, {x, 1, 10}, PlotStyle -> Red],
 AxesLabel -> {HoldForm[Voltage], HoldForm[Current]},
 PlotLabel -> None, LabelStyle -> {GrayLevel[0]}, ImageSize -> Large]
