If we place a conductor inside of uniform external electric field then opposite charges will get induced on the both sides of conductor.
What if we connect two earth wire to each side, will continuous current will flow through the conductor?
As from the positive charge induced side will take electron from ground and negative charge induced side will eject electron so will a continuous flow of current be seen in this case?
