I have a voltage supply that provides 6 V. The voltage gets run through a complex series of transistors, and the output is around 1.5 V. This is too low for the rest of my circuit to work with. In order to raise the voltage, I have the following circuit consisting of two NOT gates:
However, when the input is off, electricity is being wasted running through the 100 Ω resistor. Is there a way to create this sort of circuit without this waste? I tried connecting the input to the base of a transistor with the collector connected to + but that didn't work.
