I'm trying to find out if the main DSP core can communicate with an external DSP via I2S . I'm not sure what that strike-through means.
1 Answer
It means that it is a bus with multiple signals.
It can't be used to determine anything specific about the I2S bus, such as data direction or clock direction, but generally I2S devices are quite versatile that they can receive clocks from another device or send clocks to another device.
2\$\begingroup\$ @whoknowsmerida sometimes there will also be a small number above the strike through to indicate how many signals are in the bus. \$\endgroup\$ Commented Jan 7, 2022 at 11:02
\$\begingroup\$ @TomCarpenter Thanks Tom \$\endgroup\$ Commented Jan 12, 2022 at 2:07
