I'm trying to create some automation of switching off the CATV signal on a splitter port.
Using a regular 5V Arduino relay module I've tried to interrupt the wire from the center of the coaxial cable but it didn't work. I guess that it was due to the exposed center wires which acted like small antennas and passed through the signal through the air.
Another idea is to use some active CATV splitter and just turn off the power for the corresponding amplifier but I'm not sure that it will work either.
What would be the proper way of switching off the CATV signal on a splitter port?
Thanks!
