I am working on a project where I need to place some external antennas in an plane of around 220mm to 400mm in size.
The wireless technologies in use are WiFi 2.4/5Ghz, Bluetooth, 4G LTE, 5G NR, LoRaWAN 865 to 868MHz. We plan to use 2 antennas for WiFi-Bluetooth, 3 or 4 for Cellular (Main, Diversity, GNSS, 2x MIMO Antennas Frequency Range of cellular from 700MHz to 5GHz) and 1 antenna for LoRaWAN.
I am no RF Engineer, but I want to decide the placement of these antennas. Requirements are that the interference and coupling between antennas is minimal and these antennas perform optimally within the constraints.
Apart from the general guidelines for antennas placement such as placing the antennas at least 1/4th wavelength apart, orienting the antennas in a way that that the radiation patterns of antennas are different from each other what are the other ways to ensure optimal performance?
I would really appreciate if someone can point me to resources that will help me come up with a solution for this. Also, learnt that some antennas placement simulation software can help decide antenna placement.
What different approaches can I try to solve this?
