I am using the Explorer 16 Board for building a Accel connected by I2C . Currently I have only the I2C part done and I am trying to tap scl1 & sda1 using oscilloscope. The accel has to connected yet to the the MCU!
But on oscilloscope I dont see any signals on both SCl1,SDA1, any help ? here is the code :
UINT config1 = 0,i=0;
UINT config2 = 0;
/* Turn off I2C modules */
CloseI2C1();    //Disbale I2C1 mdolue if enabled previously
ConfigIntI2C1(MI2C_INT_OFF);  //Disable I2C interrupt
config1 = (I2C_ON  | I2C_7BIT_ADD );
config2 = 157;
OpenI2C3(config1,config2);   //configure I2C1
IdleI2C1();
StartI2C1();
while(I2C1CONbits.SEN );  //Wait till Start sequence is completed
MI2C1_Clear_Intr_Status_Bit;
  • \$\begingroup\$ Usually microcontrollers have pin multiplexing between GPIO and module functionality. Perhaps you have to change those settings so that the I2C module is what the pins are configured for. \$\endgroup\$ Mar 19, 2013 at 19:27
  • \$\begingroup\$ Which PIM are you using with your Explorer 16? \$\endgroup\$ Mar 19, 2013 at 20:30
The documentation for OpenI2Cx() says that it configures the I2C control register and the I2C baud rate generator. You still need to set up the GPIO lines themselves.
What I did in my PIC24 I2C application is:
  • Configure PPS (may not be necessary for you)
  • Disable ADC on the I2C lines
  • Set the TRIS registers on the I2C lines as inputs
