I need to measure 300VAC. I am using the following circuit and it is working good. In the circuit, I am using 2mA/2mA current transformer. More details about this transformer are available here.
However, I want to use only one power source of 3.3V to reduce my PCB size and cost. Is the following circuit good? If it is not a workable solution, pelase suggest me what would be the better solution.
EDIT:
The transformer is a current transformer with 1:1
relation of 2mA/2mA
. Also, there is a limit of secondary resistance. The secondary resistance should be less than 100 ohms
. It is not a problem to short circuit the secondary. More details are available at the following link.
https://www.micro-transformer.com/2ma-2ma-voltage-transformer-ZMPT101C.html
If I use a voltage divider (solution suggested by Kuba hasn't forgotten Monica
) as shown in the following circuit, the voltage swing at the output is little and hence, I cannot use the complete range of a microcontroller. So, I suppose the use of an operational amplifier is required.
Edit 2: Thanks to Kuba hasn't forgotten Monica
, I understood several other mistakes in my previous circuits. Upon including Kuba's
suggestions, I have the following circuit suggestion. Is it good to use a instrumentation amplifier to take full advantage of the microprocessor's ADC?
Edit 3: I came up with another circuit which seems to work fine. Please give a look at it.
Edit 4: Solution:
Finally I am able to solve it. The following circuit is working good.
