Can anyone identify the female and male connectors in the picture? Thanks
Here are some more pics Thank you.
1.56mm from pin to pin. So it should be a JST 1.25mm 2 pin micro?
what you do is read the part number off the fan and then find the data-sheet for the fan, that will tell you what the connector is.
However given the 2mm pin spacing it does look a lot like "JST PH" is the connector series here.
The "pin spacing", is from hole to hole in the connector. So the two caliper points would go in each hole. This does look like a "JST" to me (which is just some arbitrary designation), the JST's come in different "pitches" or "spacing" and have a corresponding female / mail header they fit into.
So once you figure out the pitch, then you are set to go order a matching connector.
