I derived the expression for the output voltage in this circuit, however, I have got the wrong answer. The problem is that I just know that it is the wrong answer because it's a multiple choice question and this was one of the wrong choices (hence I don't know why it is wrong - it seems correct to me!).
$$KCL_a:\frac{e_x-v_i}{R} + C\frac{dv_i}{dt} + \frac{e_x-v_o}{R} = 0$$ \$e_x = 0\$ because of virtual GND; so the equation becomes: $$\frac{-v_i}{R} + C\frac{dv_i}{dt} + \frac{-v_o}{R} = 0 \iff v_o(t) = -v_i + RC\frac{dv_i}{dt}$$
However it seems this is the wrong answer and I just don't understand why it is the case. Maybe it has to do with considering node a as it is? I think I can connect the wires into a single node at a because there is not element between.
    \$\begingroup\$ With (ex-vi)/R and with (ex-vo)/R you are saying that a positive number means current is flowing away from node A, but with C(dvi/dt) you are saying that a positive number means current is flowing towards node A. So basically you got the capacitor backwards \$\endgroup\$ Commented Aug 29, 2022 at 18:57
  • \$\begingroup\$ @user253751 has identified for you the reason why one of your signs is wrong. \$\endgroup\$
    – jonk
    Commented Aug 29, 2022 at 18:58
Well, notice that no current flows into the negative terminal of the opamp. This implies that:
$$\text{I}_{\text{R}\space\text{||}\space\text{C}}=\text{I}_\text{R}\tag1$$
Using that we can see that:
$$\text{V}_\text{i}\cdot\left(\text{R}\space\text{||}\space\frac{1}{\text{sC}}\right)^{-1}=\frac{\text{V}_--\text{V}_\text{o}}{\text{R}}\tag2$$
And \$\text{V}_-=\text{V}_+=0\space\text{V}\$.
So, we get:
$$\text{V}_\text{i}\cdot\left(\frac{\text{R}\cdot\frac{1}{\text{sC}}}{\text{R}+\frac{1}{\text{sC}}}\right)^{-1}=\text{V}_\text{i}\cdot\frac{1+\text{sCR}}{\text{R}}=\frac{0-\text{V}_\text{o}}{\text{R}}\space\Longleftrightarrow\space\text{V}_\text{i}\left(1+\text{sCR}\right)=-\text{V}_\text{o}\tag3$$
  • \$\begingroup\$ Oh! I see... so my problem was my assumption over the parallel circuit. I was interpreting it like they were not being connected in parallel but into different input sources - which is obviously wrong. Thank you for making me see that! \$\endgroup\$
    – ludicrous
    Commented Aug 29, 2022 at 18:51
  • \$\begingroup\$ @ludicrous No, you can treat them as separate 2-terminal elements that just happen to connect to the same nodes. It works out the same way. \$\endgroup\$
    – jonk
    Commented Aug 29, 2022 at 18:54
The KCL for the A node is:
$$\frac{v_{_\text{A}}}{R}+\frac{v_{_\text{A}}}{R}+C\frac{\text{d}}{\text{d}t}v_{_\text{A}}=\frac{v_{_\text{O}}}{R}+\frac{v_{_\text{I}}}{R}+C\frac{\text{d}}{\text{d}t}v_{_\text{I}}$$
or,
$$\frac{v_{_\text{A}}-v_{_\text{O}}}{R}+\frac{v_{_\text{A}}-v_{_\text{I}}}{R}+C\frac{\text{d}}{\text{d}t}\left(v_{_\text{A}}-v_{_\text{I}}\right)=0\:\text{V}$$
or, with \$v_{_\text{A}}=0\:\text{V}\$,
$$\begin{align*} -v_{_\text{O}}-v_{_\text{I}}-R\,C\,\frac{\text{d}}{\text{d}t}v_{_\text{I}}&=0\:\text{V} \\\\ -v_{_\text{O}}&=v_{_\text{I}}+R\,C\,\frac{\text{d}}{\text{d}t}v_{_\text{I}} \end{align*}$$
You could put the above into standard form for a 1st order equation and try to solve it in the time domain. Or you could cast it into Laplace notation and solve for the transfer function:
$$\begin{align*} -V_{_\text{O}}&=V_{_\text{I}}+R\,C\,sV_{_\text{I}} \\\\ -V_{_\text{O}}&=V_{_\text{I}}\left(1+R\,C\,s\right) \\\\ \frac{V_{_\text{O}}}{V_{_\text{I}}}&=-1-R\,C\,s \end{align*}$$
Not sure if that helps. But there it is.
