Why are there two collector resistors in the first circuit but in the second circuit there is only one?
What is the difference?
When there is only one collector resistor, does this affect behavior?
In the first circuit there are two outputs therefore there has to be duplicated collector resistors. This type of circuit is a differential output type. In the 2nd circuit there is only one output hence there only needs to be a single collector resistor associated with that output. It has a single-ended output.
When there is only one collector resistor, does this affect behaviour?
For the single-ended output type, not dramatically.
At the risk of over-simplifying, the transistor collectors are essentially current sources. So the collector resistor (RL in the upper diagram) has no effect on the rest of the circuit.
RL is there as a current to voltage converter thus allowing an output voltage to be passed to the next stage.
If a differential output is required, then each collector will require an RL.
If a single ended output is required then only one RL is required making the lower circuit diagram a differential to single ended converter, a common task for the input stage of an op-amp.
