Differential amplifier with a current source of 2mA and emitter resistor of 100Ω, each collector is connected to vcc = 12v. Collector resistor is 12kΩ for each resistor. It says differential input is applied between two bases. What is the input voltage Vid? (re = 50Ω) I noticed when we calculated the Ie current using Ie = 0.026/re we get Ic as 0.52mA. But 2xIc doesn't add up to 2mA which is given in the question. Any reason for that?
