This isn't supposed to be an answer but became too long for a comment.
I want to know how I can analyze this circuit.
Please don't get offended but this seems a bit too much for a beginner level. Today, even in the electrical and electronics engineering departments of universities the internals of an op-amp is kept out-of-scope.
I found that I need to break the circuit into subcircuits, but I still don't understand.
Breaking into sub-circuits and analysing each section is a good way. But
- Sectioning requires familiarity, of course. You can't make sectioning randomly. I assume you are the one who marked the sections with colourful dash-dot lines. So you should be familiar with each section.
- Sections may be meaningful with adjacent sections i.e. the sub-circuits interact with each other. So, for example, the long-tailed pair may not be fully analysed/understood without analysing the current source. Likewise, the Vbe multiplier can't work without a current source.
Now I can see a long-tailed pair, current sources/limiters, current mirrors, Vbe multiplier, and a class AB amplifier. If you want to analyse the entire circuit, you should know how to analyse these transistor circuits/amplifiers first. Then, looking at the circuit, you can analyse the interaction between each. This will hopefully make the total analyse easier.
