Write a "replace" function that replaces every character in the source string between the first occurrence of character "(" and the first following ")" with character "?". This function should return the length of the string.
Example:
before: stop playing ("the lick") all the time!
after: stop playing (??????????) all the time!
return: 39*
What I wrote looks like this:
.data
input: .space 80
prompt: .asciz  "before:    "
msg1:   .asciz  "after:     "
msg2:   .asciz  "return: "
    .text
main:
    li  a7, 4
    la  a0, prompt
    ecall
    li  a7, 8
    la  a0, input
    li  a1, 80
    ecall
    li  t0, 40  # '('
    li  t1, 41  # ')'
    li  t2, 63  # *
    li  t3, 32  # space
    li  t4, 10  # \n
    li  t5, 0 #counter
loop1:
    lbu a2, (a0)
    beq a2, t4, print #if string!=\n,go line exit and print
    beq a2, t0, loop2#if current char !=( go line 29 else go loop2:
    addi    t5, t5, 1 #add 1 to the counter
    jal a0
    #addi   a0, a0, 1 #move string to next char
    j   loop1
loop2:
    addi    t5, t5, 1 #add 1 to counter cuz '('
    addi    a0, a0, 1#move string to next char
    lbu a2, (a0) #give current a0 address to a2
    beq a2, t1, loop3 #if  != ')" go line 38 ,else go loop3:
    sb  t2, (a0) #store current t2 to a0's address
    j   loop2
loop3:
    addi    t5, t5, 1#add 1 to counter cuz ')'
    lbu a2, (a0)
    beq a2, t4, print  #if current = '\n' go print
    j   loop3
print:
    li  a7, 4
    la  a0, msg1
    ecall
    li  a7, 4
    la  a0, input
    ecall
    li  a7, 4
    la  a0, msg2
    ecall
    li  a7, 1
    add a0, t5, zero
    ecall
exit:
    li  a7, 10
    ecall
But the teacher said that although it could complete the task in this way, it was not the correct process and that I needed to use 'jal' to do it. But I have no exposure to it, so please tell me what I should do.
  • \$\begingroup\$ I am confused... I thought JAL was this, for PIC microcontrollers. \$\endgroup\$
    – rdtsc
    Commented Nov 15, 2022 at 19:09
    \$\begingroup\$ Your print seem to be incomplete. There is no return from it. The teacher might have meant that you should use jal to call it and ret to return from it. Instead it looks like it will fall through to exit and terminate right after. \$\endgroup\$
    – Eugene Sh.
    Commented Nov 15, 2022 at 19:29
    \$\begingroup\$ @rdtsc It's "jump and link" in RISC-V ISA \$\endgroup\$
    – Eugene Sh.
    Commented Nov 15, 2022 at 19:32
  • \$\begingroup\$ @EugeneSh.,I tried following the advice you gave me and it keeps reporting errors, I don't know how to use it properly \$\endgroup\$ Commented Nov 16, 2022 at 0:12
    \$\begingroup\$ Sorry, you need to describe the problem and the errors, if you need help with it. As for " I don't know how to use it properly" you can read the documentation. In the nutshell, jal is jumping to the given location while saving the address of the next instruction in ra. The ret instruction is jumping to the address stored in ra. So in conjunction they provide the mechanism of calling and returning from subroutines. \$\endgroup\$
    – Eugene Sh.
    Commented Nov 16, 2022 at 14:29
