One thing to remember is that Ohm's law, V=IR, is just a simple equation in three variables. It lets you find one value if you know the other two. If you know the voltage across a thing, and the resistance of the thing, then you can calculate the current through the thing with basic algebra.
The other thing to be aware of is that 99.99% of the power supplies you will encounter in real life are going to be constant-voltage supplies. That means they maintain a constant voltage, and allow the current to fluctuate based on the resistance presented to them. Real-world power supplies also have limits, beyond which they will start to malfunction. If you try to draw more than what it was designed for, then the voltage will start to sag, the current will drop off, the power supply will start to overheat, or some combination of the three.
Of course, constant-current power supplies exist too, but they're mostly limited to test environments.
Now, to the questions:
- Say the adapter provides 1 A and I need to calculate the voltage after the resistor. Using V = I · R, I is the current which goes through the resistor and NOT the current provided by the adapter (1 A), correct? I guess I need to put a multi-meter in the middle to find the current first.
You didn't specify a voltage for the power supply, so I'm going to assume that it's a constant-current type. That is, it will attempt to drive 1A of current through whatever it's connected to, and will vary its voltage in order to meet that demand. In this case, the voltage will be 1A · 1kΩ = 1000V.
Voltage, like motion in General Relativity, doesn't exist in isolation. It can only be measured relative to another point. So, there's no such thing as the "voltage after the resistor". There is the voltage across the resistor, which equals the voltage across the power supply since they're connected that way.
Of course, that can get complicated quickly, so usually what happens is that we pick one point and name it "0V", and measure everything else relative to that. So, if we pick the negative terminal of the power supply to be our zero point (which is typical), then the positive terminal becomes +1000V. But it would be just as correct (if much, much rarer) to say that the positive terminal is zero, and the negative terminal is at -1000V.
- What if my circuit is just a wire connecting + to - with close to zero resistance, essentially shorting the circuit? I guess at that point the current through the wire IS the maximum current provided by the adapter. Ohm's law says V = I · R = 1 · 0.1 = 0.1 V; that doesn't make sense.
If your power supply is a constant-current type (as I assumed from point #1), then it will regulate its output voltage down in order to maintain that 1A current. So, yes, if the wire's resistance is 0.1Ω, then the voltage will be 0.1V.
If your power supply is a constant-voltage type (let's assume 6V), then the current will skyrocket (up to a theoretical 60A) as it attempts to maintain that voltage across the minuscule resistance. A well-designed power supply will blow a fuse or trip a circuit breaker to protect itself from the short circuit. A more cheaply-designed power supply will set itself on fire.
- Say the adapter provides 1 A and 6 V. Ohm's law then says 6 = 1 · R which means R = 6 Ω. Now what does this represent? Is there a 6 Ω resistor in the adapter?
It's impossible to have both the voltage and the current be constant, unless the resistance across the terminals is also constant. Since power supplies can be connected to varying loads, that's obviously not the case.
Is this power supply constant-voltage? Then "6V 1A" means it will vary its current output to maintain 6V across its terminals, up to a maximum of 1A. Is this power supply constant-current? Then "6V 1A" means it will provide 1A of current output, up to a maximum of 6V across its terminals.
- Say the adapter provides 6 V and I need to find the current in my circuit, so I = V/R = 6/1000 = 6 mA?
Yep, that's correct.
- Now say my adapter provides 6 V but only gives me 0.5 mA, which means there is a 6/0.0005 = 12000 Ω resistor inside the adapter. Now my answer in [4] doesn't make sense anymore, the adapter is only providing 0.5 mA, how can the current be 6 mA in the circuit?
Again, in a constant-voltage power supply, the current listed on the sticker is only the maximum that that power supply is rated for. So, if your power supply is only rated for 0.5mA, you've overloaded it by a factor of 12, which will cause all the dire things I mentioned above.
