I have an application that uses n-channel Mosfet as a high-side switch controlled by an IC driver. The point of the Mosfet is to manage the inrush current to the load. I understand that the resistor R1 is there to prevent oscillations, but I'm not sure if I understand the rest of the circuitry connected to the gate of the Mosfet the right way.
I see the purpose of the C2 as an "additional" capacitance to increase the low internal Mosfet Gate capacitance to control the inrush current / managing the slew rate. But what's the point of R2?
I read that the R2 + C2 form a compensation network to compensate for the current control loop. If this is true, could anyone please explain how exactly it works?
  • \$\begingroup\$ My schematic is only conceptual of course but correct. The entire schematic is on the last page number 22 (Driver IC documentation). see the Mosfet named MH LINK \$\endgroup\$
    – Robert
    Commented Nov 23, 2022 at 14:07
Your R2 and C2 are used when the MOSFET (your M1) has a gate-source capacitance less than 2 nF. In the data sheet R2 is called \$R_{HG}\$ and C2 is called \$C_{HG}\$: -
And, the text from the data sheet says this: -
So, yes they are required for compensation (when the MOSFET gate capacitance is below 2 nF) and, together, they mimic the presence of a bigger MOSFET.
  • \$\begingroup\$ Thanks. It makes sense. I was confused by that "current control loop" term and expected there was also some other magic. Maybe one more question about that R2 (RHG) resistor value. I see that IC documentation claims its range, but I see no reason why they choose exactly 47 OHM in their example. Should I see the value of R2 (RHG) as an empirically chosen value, because it just works for them? Is there any generic analytical way to find its optimal value? Thanks. \$\endgroup\$
    – Robert
    Commented Nov 23, 2022 at 18:42
  • \$\begingroup\$ I don't think there is any mathematical relationship you can derive. It's case of following the data sheet. What should I do when someone answers my question?. \$\endgroup\$
    Commented Nov 23, 2022 at 18:44
