I am simulating a simple circuit with LTspice:
I was expecting V(NODE)
to be 0 at all times as U1
is an ideal op-amp, but it seems it isn't.
How can I use an ideal op-amp?
The model of the opamp you are using gives similar results to LTspice's universalopamp device which means you are not using an ideal opamp model.
The simulation below shows the results with the gain bandwidth product (GBW) equal to 10MHz and 1000MHz. You can see the 10 MHz GBW is similar to your simulation and the 1000 MHz GBW is almost similar to @usser171780's simulation with using a truly ideal opamp.
