I have a transfer function, for example:
$$H(s)= P\frac{10}{s(s+5)(s+9)}$$
See the figure below.
How do I make a linear RLC circuit from this transfer function, without using an op-amp, but a linear circuit from RLC passive components?
I have made a control circuit. I compensated the circuit so it has better settling time and good overshoot.
I usually make a simple circuit so it's easier for me to find the RLC circuit, but this one grew into a rather complex circuit and I find it confusing to make a circuit from the transfer function.
I'm trying to focus on a linear circuit. Not in the control domain; I only need to know how to go from transfer function to circuit.
I can figure out H(s) from an RLC circuit. Now I'm planning to make a method to reverse it from end to front.
Can somebody explain how to do this? I can't find any literature about it on websites.
I found out the transfer function can be separated to:
$$H(s) = 10\cdot\frac{1}{s}\cdot\frac{1}{s+5}\cdot\frac{1}{s+9}$$
Is this an answer of my problem, but it becomes an open-loop transfer function, not closed-loop. It is a closed loop but the circuit become open loop.
It becomes the same transfer function, but a different RLC circuit.
