I'm trying to make a vaporizer pipe as a hobby project. The idea is that when you inhale from it, air passes by a cartridge heater and then goes through some "herbs". A thermocouple is used to measure the temperature of the heating cartridge. A microcontroller will read out the thermocouple via the MAX6675 chip and control the power of the cartridge heater using PWM via a MOSFET, in order to keep the temperature stable at a desired value.
I bought:
- Cartridge heater Watlow C1A-9602: 24 V, 30 W, 1/8" diameter, 1" length, alloy 800 sheath
- Thermocouple Watlow 20CKFUA012A: Calibration type K, 1/8" diameter, 1/2" length, stainless steel 304 sheath
Can I solder the cartridge heater and the thermocouple together? Then heat will easily flow from the heater to the thermocouple and I get a very accurate and consistent temperature reading.
The solder must be able to withstand 250 °C (482 °F) without causing any possible problems for the user, since the user will breath the air that flows next to the solder.
What solder could I use for this? Or is this a bad idea? I looked at solder alloys on Wikipedia, but there are just too many options. Perhaps I could use the cartridge heater itself to melt the solder.
