I tried to use this module for a 4S 18650 battery pack: enter image description here Beside charge controlling it is supposed to balance cells and this is where my issue emerges. If I put some unevenly charged cells in the pack, lets say 3 cells at 3 V and one at 4 V, and connect it to a 16.8 V power supply with current limited to max 500 mA. Cells will charge till the cell that initially was at 4 V reaches 4.2 V (HY2213-BB3A overcharge detection voltage). In this point the balancer activates and discharges this cell at 60 mA. But since charging current is way more than that, charging continues till this particular cell reaches 4.25 V (the DW01 Ics overcharge protection voltage). At this moment, the DW01 IC stops the charging current and the balancer drains this cell till it drops back to 4.19 V (HY2213-BB3A overcharge release voltage). But this voltage is not yet low enough for the DW01 IC to release and let the charging process continue (DW01's overcharge release is at 4.05 V).
So now we have 3 cells at slightly above 3 V and one at 4.19 V and the charger is disconnected by DW01's command.
How is this module supposed to balance these cells?
    \$\begingroup\$ maybe the device is not designed to do that ... refer to the user manual \$\endgroup\$
    – jsotola
    Commented Jun 8, 2023 at 22:52
    \$\begingroup\$ Maybe it is supposed to balance the batteries, but can't work with that much imbalance. Or maybe it is just not very good module. Let me guess, it was cheap, bought from chinese online store and there is no manual for it? \$\endgroup\$
    – Justme
    Commented Jun 8, 2023 at 22:58
  • \$\begingroup\$ @Justme Thanks for the comment. I have asked and got a comprehensive answer about balancing capacity here: electronics.stackexchange.com/questions/669107 so I do not think that it is the matter of amount of unbalance or charging current. Apparently it is a faulty design. Yest it is a cheap 2.5$ module without a manual. \$\endgroup\$
    – AKTanara
    Commented Jun 9, 2023 at 5:19
  • \$\begingroup\$ It is NOT a faulty design. It does what the designer intended it to. it's useful when used within the limitations and it will maintain balance on battery that is reasonably balanced to start with. | My answer supplies full details of what it does and doesn't do and why. \$\endgroup\$
    – Russell McMahon
    Commented Jan 29 at 11:36
4 Answers 4
You are correct.
It's a faulty design, for the exact reasons you explained so well.
Any BMS for more than one cell in series that uses the DW01 IC (designed for a single cell) is a troubling one.
Return that BMS to the vendor and explain why.
  • \$\begingroup\$ Thanks. I have an alternative simple and cheap design in my mind that probably will ask today and I hope you do not mind taking a look at it and give your precious opinion about it. Also, thank you for editing the text of my question. \$\endgroup\$
    – AKTanara
    Commented Jun 9, 2023 at 5:56
If you fully charge all cells equally (and or make sure internal resistances are equivalent match) as you're supposed to do when making a battery pack, then any voltage drift, overtime, of a battery will be small and the current you measured that started balancing should be perfectly fine - eventually over time.
  • \$\begingroup\$ Exactly this. This circuit isn't intended to fully balance and charge in one go. It is intended that over a lot of use, the cells eventually end up balanced. Yet it handles making sure that when balancing isn't yet complete the charging process gets stopped. Ie. it is always safe, but it doesn't guarantee full pack capacity right away. This is probably a good move, since the balancing process is lossy, so you don't want to fully balance on every charge/discharge cycle if you care about energy efficiency (or use a capacitive or inductive balancer instead) \$\endgroup\$ Commented Dec 21, 2023 at 16:37
Interestingly I walked into a similar topic with HY2213, but with another PCM chip, the S-8254A from ABLIC. It has the same function as the DW01C mentioned above. It prevents overcurrent, overvoltage and undervoltage.
The concept of passive balancing with relatively low currents is well established. I made once a BMS with the TI BQ76940 AFE for a 13s battery pack. The balancing current was also only 100mA with the TI chip. Otherwise the power loss and heat was too much for small SMD resistors.
As mentioned from Russel, this concept of balancing works only well as long as the cells are well matched at the beginning. It really can prevent, that they drift too much over time and cycles. To balance cells with more difference, you need more balancing current or active balancing. But in my opinion, for normal use applications such solutions are overkill.
I have built a small power bank with 4s Samsung35cells, the above mentioned PCM and a 4 cell balancer with the HY2213. After a while, I assume after 20 to 30 full discharge and charge cycles, I found, that one cell has heavily drifted. When the other cells had 4.2V and the charger stopped, this cell only reached around 3.9V. I measured then the cell balancer and found that it worked well. All 4 HY2213 worked as expected, they switched on at 4.20V and switched off at 4.195V. Also I didn't found excessive quiescent currents. The same for the voltage measurement of the S-8254A. (Voltage threshold 4.25V +/- 0.025V)
Then I measured the charger and found the problem there. The charger is a quite cheap 1A, 16.8V plug-in charger. It has a bit a weird charging characteristic. It charges with 1A until around 15V and then decreases slowly to 0A at 16.8V exactly. Charger characteristics
This leads to another problem of this type of passive balancing. This will also amplify a drift on the cells, if one cell is only sligthly weaker than the others. The charger is simply not able to deliver the additional current to bring up the voltage threshold of the HY2213 to 4.2V on the other cells. So this results in no balancing at all.
As a conclusion we can say that this type of PCM and balancing are not bad at all, but everything must be well balanced, the PCM overvoltage protection, the balancing threshold, the balancing current and the charging current at 16.8V. In fact it would be difficult to find a charger with a sharp change from CC to CV at exactly 16.80V which would be necessary to make the circuit work well.
TL;DR:
  • The design is not faulty.
  • Products may exist that will take a random collection of grossly differently charged cells and balance them in a single pass with the accompanying charger set at its full charge settings, but this is not one of them, and it is not designed to be.
  • The BMS will not instantly balance cells which are grossly mismatched.
    When building a battery pack from individual cells "standard procedure" is that all cells should be of the same type, they should all have the same "history" of use, and all should be at the same state of charge.
  • This BMS will correctly balance a collection of grossly imbalance cells IF the accompanying charger is set to a charge rate less than the balancer capacity.
__________________________
Today (January 2024) I received 6 of the LiFePO4 version and 4 of the LiIon version of these BMS modules from China. That makes your question, and a good answer, of more interest to me than to most people :-). So -
The issue is not so much that the BMS is faulty or that the design is bad, but that the design has limitations due to the cost/complexity tradeoffs that have been made. The limitation that you raise is unimportant if the aim is to ensure that initially well balanced cells stay that way.
For large imbalances it happens that the issue that you raise can (probably) be simply and easily addressed.
It's important to note that the DW01C (or equivalent part) achieves over and under discharge control and plays no part in the balancing. You show that you know this, but it's important to an understanding of the overall operation.
Also, it's not obvious without a circuit diagram (and / or having a module at your right hand as you type, as I do), that the large FETs are NOT equipped on a per-cell basis but, rather, all the N channels are in parallel and all the P channels are in parallel. The H6N03LA N CHANNEL FETS (datasheet here ) and equivalent P channel ones are rated at about 50A continuous with an infinite heatsink. The limit here is mainly the achievable heatsinking. [My versions use different FETs but with similar ratings.]
Rdson is around 10 milliohms, so with 5 in parallel the track and any connector resistances probably predominate.
[My units are rated at a nominal 30A. At 30A/5 = 6A per FET dissipation is notionally I^R ~= 0.4 W/FET. With 10 in proximity the 4W dissipation may be tolerable.]
To first answer your main question, the module will balance the battery if you
  • Charge it until it stops charging as described above.
  • Discharge the battery 'somewhat' until the most charged cell's voltage drops below 4.2V.
  • Now, charge the battery at a current lower than the rated balance current - in this case about 60 mA.
In designing a BMS like this one there are compromises between cost, capability and so complexity. The BMS IS intended to be used with a charger and is NOT intended to be used without an accompanying charger. In this case, one thing that the charger will do is limit total battery voltage to 4 x Vcell_max - usually 4 x 4.2V = 16.8V. You are correctly matching this with your " ... connect it to a 16.8 V power supply with current limited to max 500 mA" power supply".
If all cells are reasonably well but not completely balanced then as one cell reaches 4.2V the battery as a whole will be close to entering the CV portion of its CCCV charging cycle, and the most charged cell will be requiring CV balancing. At 4.2V the cell will not stop drawing current BUT the now active discharger will reduce charge current for that cell from Icc to Icv-Idischarge = 500-60 = 440 mA. The cell will be held initially at 4.2V by the discharge and as it is starting down it's CV current tapering it will for a short while tend to stay at 4.2V.
IF the other cells are 'not too far behind" they will 'soon' afterwards reach 4.2V and also enter what should be the CC phase. As the charger (in this case power supply) is set to 16.8V the battery as a whole will be in CV mode, current will begin to decrease, and all will be well.
However, in your case you suggested starting 3 cells at Vcell = 3V and one at 4V. This is so immensely out of balance that the inevitable result is the most charged cell's voltage shortly recommencing rising until the overvoltage protection shuts down the whole pack, as you observe.
The only way to achieve balance would be to shunt 100% of the charge current from the most charged cell. In this case that's 500 mA and Rdischarge would be <= 4.2V/500 mA = <= ~ 8.4 Ohm at a dissipation of 4.2 Vx 500 mA = 2.1 W. That is entirely doable. Surprisingly, the existing discharge FETs are probably adequate to the task. The FETS labelled SH2B are S12303 (datasheet here ) rated at 20 V,2.8A max, 600 mA continuous and, crucially, about 70 milliohm Rdson. Dissipation at 500 mA = I^2R = 0.5^2x 0.070 ~= 20 milliwatts (!!!).
So, replace the discharge resistors with say 8 Ohm 5 Watt parts (probably offboard and immediately adjacent) and it may balance even your immensely imbalanced example.
Superb analysis
Here - "Lithium Ion Battery Management and Protection Module (BMS ) Teardown - Schematics, Parts List and Working" is an immensely detailed, competent and useful analysis of the BMS in question. He does not really comment on the limitations that you are asking about, but his explanations demonstrate that the designer chose not to address the extreme cases that they represent.
Here is one "channel" of the BMs showing the DW01C (or equivalent) at left controlling a shared-with-all-channels over/under discharge shutdown mechanism, and at right the completely independent HY2213 balance / discharge control IC. Replace R40 for an 8 Ohm 3W (5w safer) resistor and it will (probably) balance anything at 500 mA max charge or rest.
