I'm trying to configure the regulator to output 4.5V. From what I gather, the output voltage is governed by the voltage divider between Vo and GND where the device's FB pin reads the voltage dropped across R2. However, as the applied voltage to the regulator changes, so does the output voltage. This seems like it will be a problem since the applied voltage will come from an unregulated battery supply of 4 NiMH batteries, which should drop from ~5.6V to ~4.8V before cut-off. If Vo changes depending on the applied voltage, how can a voltage divider be configured to maintain a consistent 4.5V for Vo?
Image from Datasheet here
The datasheet can be found at the following link: https://www.digikey.ca/en/products/detail/rohm-semiconductor/BD00FC0WFP-E2/7896451
Below is a screen capture of the LDO regulator circuit diagram:
