I need to order a 32 pin LQFP chip and replace it with another 32 pin TQFP chip so is it ok to replace it or it won't be compatible?
The chip is an STM8S003K3 MCU
If you refer to the datasheet, it does not appear to be offered by ST in a TQFP package, only 0.8mm pitch LQFP32 in 32-pins.
So whatever it is that you are potentially ordering is either not ST or there is an error of some kind. I suggest you get to the bottom of it before placing an order.
