I am doing some practice questions. However, there doesn't appear to be any answers online. Therefore, I am checking if I am correct here. Could you please let me know if my analysis and calculations are correct.
The last Resistor R8 is short. Therefore, it is ignored and current will go through the short instead. R6 & R7 are in parallel 12||4 = 4 Ohms and R4 & R5 are in parallel too. 4 || 4 = 2 Ohms.
The calculated Ohms of those two parallel branches are added to R3 since they're now in series. Therefore, (3 + 4 + 2)Ohms = 9 Ohms. This is now in parallel with R2 which is 18 Ohms. 9 || 18 = 6 Ohms, plus R1 of 6 Ohms. Total resistance is 12 Ohms.
Source current = 54/12 = 4.5A
Current across I8 and V8 is 0 since this is short.
