I have a DC motor controller that clearly says to use a battery and not to run it from a power supply because of the likelyhood of the regenerative power damaging the controller.
Unfortunately, this is not an option for me as I have to use a power supply and not have a battery to place in parallel to absorb the excess energy.
If I use a reverse biased diode would that prevent the regenerative power from damaging the controller? If so how do I implement it correctly or is there better method?
Also, there would never be a situation where the power to the 12V BLDC motor would be abruptly terminated, as it would always be slowly powered down. If that is the case, do I even need to be concerned about the regenerative power damaging the controller?
