I have a PTZ camera which has 9-pin USB B device. When I plug into to the USB it shows the error power surge. I knew something was burned out and opened the device to check and found out that one of the rectifier diode right next to the USB input is blown out, unfortunately I couldn't see the markings (value number) on it. I have a basic to intermediate knowledge in electronics working could identify most of the components diode is VD2 in the image:
I would like to know how to calculate in choose a diode that fits for it. I tried checking online but unable to find. This PTZ camera has both USB and external power supply to work with. USB video transmission and power supply for motors.
Any information or reference would be highly helpful for me.
Update:
Camera is connected through usb 3.0 pcie express card and 12v external power source. While using the camera smoke started coming out and showed an error power surge.
I have removed the diode and it no longer gives me an error but camera also works perfectly. I guess the diode must be regulating voltage Or esd not exactly sure. Which diode and value should I use to protect the camera again with the usb surge.
