I'd like to drive a 24 VAC solenoid (an Irritrol series 700 sprinkler valve solenoid) with the secondary voltage from a plugin transformer (a Vitek model VT-24VAC/20).
Checking this on the bench, I separately connect/touch the two solenoid input leads to the two transformer secondary output contacts, the solenoid "clicks" but...
Problem: The solenoid continuously buzzes.
Question: What does the buzz indicate?
(I reviewed Circuit for opening/closing sprinkler valve solenoid?)
