Can anyone help me to identify this SMD part?
If I measured the size correctly as 1812, then it's a Littelfuse 1812L200TH PTC resettable fuse.
(Source: lcsc.com)
  • \$\begingroup\$ Thank you so much \$\endgroup\$ Commented Sep 6, 2023 at 18:26
  • \$\begingroup\$ is this the same part? ebay.co.uk/itm/394802612905 \$\endgroup\$ Commented Sep 6, 2023 at 18:29
  • \$\begingroup\$ @JohnnySmartCar No, that's a different size. If you measure the part you will find the exact size. I tried to measure it from known sizes in the picture, but that's not always exact. \$\endgroup\$
    – nanash1
    Commented Sep 6, 2023 at 18:31
  • \$\begingroup\$ measures approx 4-5mm does that sound right to you? \$\endgroup\$ Commented Sep 6, 2023 at 18:48
    \$\begingroup\$ 4.6mm x 3mm is the correct one after a remeasure, dis this the correct one ebay.co.uk/itm/181883216045 thanks for your help \$\endgroup\$ Commented Sep 6, 2023 at 19:07
