I'm using the LED driver PCA9633 (8-pin.) After reboot, with default settings, the output of the LED pins are high, turning the LEDs on at reboot.
- Is there a good reason why I should want this?
- Is there a similar chip with default output state low?
Relevant default values:
- SLEEP = 1 (low power mode, oscillator off)
- INVRT = 0 (output logic state not inverted, value to use when no external driver used)
- OUTDRV = 1 (LED outputs are configured with a totem pole structure)
- LEDOUT = 00000000 (LED driver is off)
The 8-pin version doesn't have an OE pin.
The datasheet states:
If LEDOUT = 00, INVRT = 0, and OUTDRV = 1, LED state = VDD.
I'm using 12V LEDs, connected as shown at LED3 of the typical application:
I don't want to turn off the LEDs immediately after startup, the peak current at startup might cause problems. I'd like to avoid using additional hardware inverting the output signal.
