I've got this circuit and I'm wondering if my logic is messed up when calculating current.
I calculate total current in the circuit by finding resistances of the resistors in parallel and then adding those in series with the 800 Ω resistor.
So:
$$ R_{top} = \left( \frac{1}{4k} + \frac{1}{2k} \right)^{-1} \Omega = 1333.333 \; \Omega $$
Then the bottom parallel:
$$R_{bottom} = \left( \frac{1}{400} + \frac{1}{1.6k} \right)^{-1} \Omega = 320 \; \Omega $$
Then I add those 2 resistors in series with the \$800 \Omega\$ resistor to get a total circuit resistance of \$2453.33 \Omega\$
Then I say
$$ I=\frac{V}{R} = \frac{8}{2453.333} A = 3.26 \; {mA} $$
Does this work out? Or is my logic incorrect?
