I'm trying to use the signal generator from a DSO Nano v2 to drive an Arduino interrupt for testing purposes. I have measured the output of the signal generator at approximately 13mA @ 2V DC.
I have tried using a 4N28 optcoupler alone but I found that the voltage differential at the output was nowhere near enough to trigger the interrupt (it was ~0.4V), I assume there is not enough input current for the IR LED to saturate the transistor.
How can I make this work? Also, would this solution apply for other comparatively weak signal sources.
Would an opamp be able to boost the output signal?
