The circuit under consideration is to be powered by four 18650 li-ion cells in series. These cells are in a holder and user replaceable so there is risk of the contacts being touched and adding esd protection might be wise.
The biggest problem is a CD40109, which is powered straight from the battery. Parameters of concern for this chip are:
- Absolute maximum supply voltage: 20V
- Recommended maximum supply voltage: 18V
Four, fully charged, 18650 cells in series will provide ~16.8V (4x 4.2V)
The problem is that TVS diodes with a reverse stand-off/working voltage of >16.8V but with a clamping voltage <= 20V don't seem to exist. What would be good ways to handle this situation?
I'm thinking along the lines of the following:
Selecting a TVS diode with a higher clamping voltage such as 30~35V and then feeding the CD40109 trough a RC. With the input clamped at 35V during a ESD event it takes ~40µs for the capacitor to charge from 16.8 to 20V with the values given, which seems enough to survive a standard 8/20µs event. The CD40109 is not driving any significant loads, so 22 ohm in the power feed is no problem. Any problems with this idea? Better ideas?
